Greetings,
I’m away from the car and trying to do reserach on this so that I’m good to go when I get back. ’74 - single turn signal indicator tach.
Most have a constant flash from not resetting the MC switch after a brake issue or a ground issue at the e-brake handle. Mine seems to be the opposite - I have no light/flash.
No e-brake flashing light in the gauge and no clicks can be heard when e-brake is pulled.
turn signals/4-ways - everything else functions/flashes as normal.
e-brake switch and ground wire at the handle appear to be ok.
Is my flasher bad/incorrect? @Spoke - do I need one of your EP26’s? I’m wondering this because the car is new to me and may have had the relay replaced with an improper replacement (I know they’re not really available…)
