Hello,
in my 1972 914 I recently installed a remote mounted amplifier (Sony 222w) and hooked up the original radio (Motorola mono FM) along with a bluetooth receiver. Everything worked great for a few days, until something weird started happening. If I run the audio system with the engine off, everything is perfect. However, if I run it while the car is running, every few minutes the audio will cut off completely for a few seconds (sometimes even one minute), and then everything will come back to normal again.
Also, once in a while I get some low frequency hum through the speakers that will last for 5-10 minutes. When this happens other events that affect the electrical system (for example, using the blinkers) will produce noise in the audio system. This only happens while the hum is going on.
Any suggestions? It feels as if there are maybe some electrical spikes in the electrical system, and the amp must be having some protection that shuts it off temporarily.
Thanks,
Andrei.
