ruddyboys
Jun 25 2005, 10:41 PM
Checking my lights i notice my the small light bulb in the conor of my right rear directional isn't lite. figuring a burnt bulb or corroded connection. i turn off the power, but leave the right directional lever on. the directional light is lite without blinking and wow that small bulb is lite. i turn the ignition on and the blinking starts but that small bulb is out again. what gives.
Jun 25 2005, 11:00 PM
QUOTE (ruddyboys @ Jun 25 2005, 09:41 PM) |
what gives. |
wiring screwed up? the little bulb should just come on with the normal lights, kinda like rear sidemarkers ...
the blinker being on steady when ign. off and turn signal lever moved in either direction is OK, it's a european thing.
parking lights that can be switch on for either the left or right side.
used for nighttime parking on the side of the road ...
Andy
Joe Bob
Jun 26 2005, 12:03 AM
parking light....gud opening line when a "betty" says..hey stoopid yer lights are on...you tell them...it's a euro thang....gets ya laid 1 time in a 100...
jgiroux67
Jun 26 2005, 01:08 AM
QUOTE (Sir Fartalot @ Jun 25 2005, 10:03 PM) |
parking light....gud opening line when a "betty" says..hey stoopid yer lights are on...you tell them...it's a euro thang....gets ya laid 1 time in a 100... |
I dont know why, but thats cracking me up
lylegd
Jun 26 2005, 08:48 AM
There is a small wiring harness inside the tailight housing that you need to check out. There are two screws that hold the reflector inside the housing and the harness is right behind it.
Hard to believe but after som many years, broken wires and corrosion can occur inside the housings!
