Hi Guys,
I have a 76 with a 2056 running D-Jet with a 123 Distributor. I've been sorting out vacuum line connections, and I can figure most/all of it out from Bowsby's drawings. What I really could use though is some photographs of how folks have made the actual connections, particularly to the ports below the throttle body in the intake plenum. The air cleaner ones would be useful too.
A couple examples of things done by the PO are that the oil filler vent is plumbed to the large opening on the top of the air cleaner, not below the throttle plate. Another is the AAR is not connected to the air cleaner, it is plumbed to a small K&N crankcase breather. I need to get this sorted out reasonably well so I can then put the smoke machine to it and test for leaks. For those of you who have done this, where did you attach the smoke machine, and what did you plug and cover?
Thanks for any helpful advice!
