Yesterday was my final straw at trying to resolve my sporadic engine stalling issues. Over the past few months I have been replacing various components in an effort to resolve my intermittent engine runnability. The primary focus had been coil, wiring, distributor and ignition parts. Thanks to many helpful tip from this site I narrowed the problem down to the fuel pump not getting current on occasion. My relays seemed OK so I thought the problem might be coming from the ECU occasionally thinking the engine RPMs had dropped below 100. My understanding is that this is fuel cut out is to prevent some engine issue. Using my volt/ohm meter in the cockpit as pictured I attached a lead to Pin 3 on the relay board to see if the ECU would occasionally drop the ground on the fuel pump relay circuit. To my confusion I was getting erratic measurements as I took a ride down the street. The car was bucking and surging and stalling. About a mile away from home my intermittent running issue became a full-time problem. I could activate the fuel pump as I turned the key just like it is designed to do but once the starter engaged the engine only ran for a few seconds apparently from the initial fuel pressurization but the that was all she wrote.
I limped home and it looks like by hot wiring the fuel pump I will be able to drive it to a local import car shop that has a mechanic familiar with D Jet systems. Despite my frustrations and throwing in the DIY towel, I am glad that this problem is continuous which should make it easier fix.
I will post what it took to resolve this problem once I get it back. My shop appointment is 3 weeks out yet....
