Look well made and specific to T4 engines,$46USD with free shipping..could you really go wrong .
The description has no details on the type of manifold fitment so I presume it works with the tall ones as they are common.
I think they look similar to the system that came on the Brazil built 1600 twin Solex carb busses we used to get years ago in my country,I designed a system off this setup and used it on my offroader with Weber ICT's to good result,once setup I never adjusted it again.
The Brazilian linkage was poorly made with very small diameter pivot joints that wore out fast, the pivot crank suffered the same wear issues also.
This kit appears to be an improvement on the above.
