Geezer914
Jun 23 2019, 03:57 AM
Coming home from a friends house last night the car started bucking. Luckily I just made it home.
Where to start?
jim_hoyland
Jun 23 2019, 06:48 AM
Try looking at:
http://www.914world.com/bbs2/index.php?sho...&hl=buckingBTW-Found this thread by doing a search using +bucking, then selected titles only; a whole page of threads appear with "bucking" in the titles.
Good luck with this one, keep us posted;If I'm the next one to experience bucking, I'll rely on your analysis.....
Geezer914
Jun 23 2019, 09:16 AM
Thanks for all the reply's. I'll do the search on bucking.
Porschef
Jun 23 2019, 09:48 AM
Dual relay, then vacuum leak
rfinegan
Jun 23 2019, 11:44 AM
when my 1.8 was bucking it was the connector at the AFM. I had a pin or 2 push out of the connector and intermittent contact. ez fix and problem solved for me...
jim_hoyland
Jun 23 2019, 03:42 PM
My 1.8 L-Jet never went through biking episodes; but if it did, the first thing I would check is the connector at the dual relay. The connector on the left side has 12v in, ground, starter, and fuel pump ( black/red). If that fuel pump connector is not making good contact, the fuel pump will go off/on.
I aventually connected those wires directly to the dual relay.
Jun 23 2019, 03:53 PM
My car bucked off and on for over 6 months. I did a bunch of things but I believe it was overhauling the distributor that fixed it.
ClayPerrine
Jun 23 2019, 09:40 PM
Check the ground contacts at the rear center of the motor. Broken or loose grounds can cause bucking.
Dropping resistors can cause this also. They have a tendency to break wires in them.
With a 914, it's always the grounds. Except when it's not the grounds.
Geezer914
Jun 24 2019, 11:45 AM
Tested the coil it read 9380 ohms from the negative post to the center. My spare coil read 8500 ohms. I think the coil over heated. I swapped out the coil and replaced the plugs, cap, and rotor. It has a Petronics ignition module. It ran great, but I need to take an drive for an hour or so to let things get hot and see if the same symptoms develop.
Geezer914
Jun 29 2019, 04:27 PM
Took a 45 minute drive and everything ran fine. Ordered a CHT from 914 Rubber to install for piece of mind.
