QUOTE(Chi-town @ Jun 23 2019, 07:40 PM)
If you want to swap to a later column you'll be doing some wiring as all the connectors are different.
If it only were that easy. I've done that swap and it involves a lot of cutting and grinding and swearing and then you still end up with completely incompatible electric connections.
The later columns not only have different mounting, they also have a different depth, meaning you will have to customize the steering shaft (more grinding) to get a geometry that doesn't bind. (And no, the later steering shafts won't work).
It's absolutely not worth it, would not do it again ...
