exsurfer
Jun 25 2019, 06:03 PM
I need to change the isolater on my 914-6 because the threads were
damage when the pump was removed. The damaged isolater is the lower of the two. I can't get the isolater to unscrew from the body. my thought was to unscrew the isolater install an new one. Ha! it will not unscrew from the body.
Anybody been there done that ........HELP loosing a lot of time on this.
Thanks very much
Mark Henry
Jun 25 2019, 07:37 PM
I don't know the /6 pump but isn't the isolators mounted on a clamp?
Mark Henry
Jun 25 2019, 07:43 PM
Oh the body of the car.
Torch, tap with hammer, vice grips.
Break off the rubber down to the metal stud first, might even come off without heat, just the vice grips.
It's a weld nut on the body you have to get the nut hot.
jcd914
Jun 25 2019, 09:42 PM
QUOTE(Mark Henry @ Jun 25 2019, 06:43 PM)
Is it a welded nut?
PET shows separate 6mm nuts and washers on the top of the sheet metal engine shelf.
The ones on my car (72 4cyl) look permeantly attached with layers of paint but it appears to be a nut, lock washer and a flat washer. Kind of tough to see with the FI control unit in the way.
Would be tough to hold the isolator and undo the nut with the engine in place sence they are on opposite sides of the engine shelf.
Jim
Mark Henry
Jun 26 2019, 07:36 PM
Come to think of it I believe you're right, top of the shelf is a 6mm nut.
Vice grips on the old isolator and a 10mm socket should do it.
exsurfer
Jun 27 2019, 08:45 AM
You lost me. The lower isolator turns with vice grips when turned to the left. The isolator
doesn't increase the distance between the frame and the lsolator. I'm stopped at the
moment. A serviceable isolator seems essential. Did the weld nut fail allowing the nut to
turn?
I have no experience with the four cyl. equipment.
Mark Henry
Jun 27 2019, 09:31 AM
You need to post pics, we don't even know if it's factory or something a PO cobbled together.
McMark
Jun 27 2019, 09:38 AM
They're not weld nuts. Just 6mm holes in the body. You're just dealing with normal 50yr old car stuff. The fasteners are rusted together. And getting these free can be a special pain in the ass, since the rubber mount has very little to grab onto and anything that sparks puts you at risk for fire.
DON'T use the URO ones, they're way too soft. Suitable replacements are available from McMaster-Carr.
dr914@autoatlanta.com
Jun 27 2019, 11:06 AM
yup that is the way, the two mounts are small rubber pucks with a stud on each end the upper secured to the engine shelf with. 6mm (10mm headed) nut and washer and lock. You can grind the head of the stud/nut off and free the hole, clean it up and touch it up, as obviously there is rust in the area
exsurfer
Jun 27 2019, 11:47 AM
This car is original 80K miles. No cobbled job on this area. What is the engine shelf
ya'll refer to? I'll try to get a picture later today. Car has sat over ten years in my
garage. No rust in the area. Car is almost rust free.
Thanks for the help. I'll try to get pictures.
Mark Henry
Jun 27 2019, 03:58 PM
Engine shelf is the part of the body that meets up with the engine tin surround. The nuts are below the front of the battery support, right near the hell hole, a PITA to get at but doable.
Jun 27 2019, 04:16 PM
you can get to the top nut for the fuel pump mount just in front of where the fuel lines both come through the engine shelf. Even if the car is very clean, the nuts may be rusted and will need a squirt of pb blaster and then worked for awhile to loosen and remove.
QUOTE(exsurfer @ Jun 27 2019, 10:47 AM)
exsurfer
Jun 28 2019, 10:51 AM
Here is the picture of the isolators on the right side of the engine compartment
below the engine tin. Bottom one will not unscrew.
The two lines are fuel supply and return.
Thanks for your attention.
Gene
IronHillRestorations
Jun 28 2019, 11:45 AM
FWIW Seafoam Deep Creep is the best penetrating fluid you can buy. 1 part ATF to 1 part acetone is very effective too.
thelogo
Jun 28 2019, 11:53 AM
Looks like a job for ant man
I couldnt get my arm im there and do anything productive .... But when your stuck in sunland or la canada ..... You gotta call leman or lemon ...
exsurfer
Jun 28 2019, 01:09 PM
QUOTE(thelogo @ Jun 28 2019, 12:53 PM)
I'll give Leamon a call. He is a very great resource.
Gene
thelogo
Jun 28 2019, 05:33 PM
QUOTE(exsurfer @ Jun 28 2019, 12:09 PM)
Gene
Just dont let him buy the car from you
jcd914
Jun 28 2019, 06:10 PM
QUOTE(exsurfer @ Jun 28 2019, 09:51 AM)
Gene
Gene,
You need a helper to get that loose.
Directly on the other side of the sheet metal the isolator is attached to, is the nut holding the isolator on.
You can't get to the nuts from under the car with the engine in the car so you need someone to be under the car and hold the isolator from turning and someone else to reach into the engine compartment from above and loosen the nut.
Jim
exsurfer
Jun 28 2019, 06:23 PM
QUOTE(thelogo @ Jun 28 2019, 06:33 PM)
Gene
Leamon is the only other person who has driven the car. He's not that
interested in completely stock original car even if it's a 71.
exsurfer
Jun 28 2019, 06:27 PM
QUOTE(jcd914 @ Jun 28 2019, 07:10 PM)
Gene
Gene,
Jim
The "other side" isn't accessable. If it is I'll need a map. I'll get it, when is another story!
johnhora
Jun 28 2019, 06:41 PM
knew I had a pic somewhere
topside view of the isolators on the right side of the engine compartment
exsurfer
Jun 29 2019, 07:09 AM
Was your car a factory six or a conversion from a four? I don't have the
same configuration on my factory 71 six cyl.
I want to assure that we are dealing with equal cars.
THANK YOU! I hope your correct!!!
exsurfer
Jun 29 2019, 07:10 AM
exsurfer
Jun 29 2019, 10:20 AM
I see said the blind man!!!!!
I found the nuts per the last picture posted!
THANK YOU !!!!!!!!!!!!!!!!!!!!
MY CAR HAS quite a few smog lines there but at long last
I see.
