@kylefromcanada You have a distributor from a D Jet 914 engine. Did not check the number to see which one. There are slight differences in them but you can use any D jet distributor on and D jet motor.
See if it holds vacuum on both sides of the vacuum canister. Most leak. That is a plus if it does.. Does it spin freely and not have play in the shaft ? I have about 20 and might have 2 good ones. There is not much call for distributors.
Good luck with the sale
