QUOTE(mepstein @ Jul 4 2019, 08:53 PM)
QUOTE(Biggles @ Jul 4 2019, 03:23 PM)
QUOTE(Retroracer @ Jul 3 2019, 06:44 PM)
SO I recently went for Falken's, 215/60x15 rear and 205/60x15 front. Of the (limited) choices out there, these seemed good value and they seem to grip well:
If price was no object I'd go for the TB15's (as mentioned further up the thread),
- Tony
Got these in my car. Done c5k miles and work very well. Also with that tyre size, they look right / fill the arch properly - so many don’t IMO
@Biggles What size are you running? I was concerned the 23/62 - 15 TB 15 - might be too wide for the rear. I run 7x8x15.
Sizes - Equivalent metric designation + load and speed index - Overall diameter (mm) -
Rolling circ. (mm) - Rims Section width/rims mm/inches
18/60 - 15 TB 15 215/55 R 15 79 V 612 1885 6 to 7,5 inches 224 / 7
23/62 - 15 TB 15 270/45 R 15 86 V 625 1923 8,5 to 10,5 inches 268 / 9
I'm running:
7 x 15 (f) with Falken 205/60/15 91V
8 x 15 ® with Falken 225/60/15 96W
below you can see how it fills the arch (albeit the rear is sitting about 1.5" too low at the moment) and a TB15 on a GT car for comparison
I'm also considering going 195/65/15 on the front to see if it helps ease the load on the steering. Comparing to a standard non-flared car, it feels heavy, which I think is mostly attributed a lot to the wheel spacers, but a narrow tyre will help
Sorry, I thought you had the Michalins. Heavy steering doesn't have to be the tires or the track width. We had an RSR with wide wheels and tires and it drove with a light touch. Proper alignment is huge.
