It has gotten to the point where I can’t really do a much more work myself to clean up or paint the engine compartment in my 914 to be ready to accept the 3.0 -6. I am putting the front suspension back on this week and ideally I would like to tow it to someone’s shop so that they can tidy up the engine compartment. It needs to be cleaned, prepped and painted. I’ve drilled the drivers side for the -6 oil tank provisions and would need to remove a couple unneeded brackets and probably replace the battery tray along with some light hell-hole repair... (there was some previous repair work in the hell-hole, the longitudinal and the door latch but I believe primarily structural stuff is ok, so hopefully the hell-hole just needs to be tidied up). I also don’t weld so Ild like to find someone to help me weld the Naro Escape 914-6 mount in the car... even in my garage prior to taking it to paint if that makes it easier. I have a 240v outlet
Anyone suggest or recommend anyone or any shop around the Baltimore area?
Thanks in advance.
- Rich Pugh
