The pictures did not turn out like I had hoped. But here is the story.
A couple years ago I had my TB rebuilt. Yesterday I used a smoke machine on the FI system. Found nothing of real consequence.
The problem is that if the engine is not too hot, at idle it goes down to 1400. 90 seconds at a stop sign or coasting and the RPM will drop to about 1000. Now that is what happened today and has happened since I started driving. seems right, but takes a while.
If the engine is good and hot... OT around 240, air temp 90+ idle will quickly drop to under 1000 and sometimes die. Gonna drive tomorrow and see if that continues.
the pictures are the idle adjustment screw. I noticed today that it would turn with ZERO effort. it looks like the plastic in the threads is taken on the shape of the threads and no longer holds. Can I buy a brand new screw?
I did replace the o-ring today. You can see the btm picture, it is a bit fatter and seemed to hold slightly better. No real change.
What can I try next?
