SOLD 8/10/19 - thanks to all for interest!
Price drop to $9,500 - cutting $10,000 off the ask due to lack of interest and PPI issues. Price is for car only - no longer includes spare parts, no longer includes cover which will be sold separately.
At this price, you are getting an imperfectly restored car with 400 hours of welding work completed, 400 hours of bodywork, paint prep, and new paint, all interior parts, Fuchs rims, powdercoated suspension, and all hardware rebuilt, completely assembled and ready to drive. Or, part it and profit.
PPI findings copied and pasted below. PPI was performed by A&P Specialties in Portland. Can't link to the online document as a potential buyer's info is included:
Body and Frame
Technician Notes
Car has been hit on passenger side at one time, passenger door is a little off. This may need a body shop to further inspection. I don't see any issue with the frame at all. Various small dings in pictures below.
Miscellaneous Items
Technician Notes
Oil leaks!, Engine case bolt on driver's side seeping oil!, Oil sump plate minor seepage, Silicon sealer was used on most gaskets even push rod tubes!! They aren't leaking at this time. Drivers valve cover has very minor seepage may need to be re bent.
Inspect Front Brakes
Technician Notes
Some minor wheel damage. Front pads approximately 70% material, brake fluid looks clean, however reservoir cap may be leaking. There is fluid in the cupped are of the reservoir..
Inspect Rear Brakes
Technician Notes
Rear pads approximately 95%, emergency brake cables to control arms needs circlip, one is missing, and the other is just missinstalled, easy to fix.
Inspect Exterior Lighting
Technician Notes
Left rear liscense plate light is out!
Inspect Interior Lighting
Technician Notes
Main dome light is inop, footwell lights have been installed, aftermarket. (OWNER'S NOTE: cabin light - aftermarked - is NOT inop, it is wired to only come on with ignition.)
Perform Battery Test
Technician Notes
Battery tests ok, positive cable from starter is getting old, no corrosion at this time!
Inspect Exhaust System
Technician Notes
Has fairly new heat exchangers, rear muffler sounds just fine, however has some minor rust repaired holes. Seems ok..
Technician Notes
Interior dashboard, drivers door pocket, pop top trim I'll have some cracking.
Seats and seat belts
Technician Notes
Seats have some damage,
Miscellaneous Items
Technician Notes
Found initial co% was set high, reset for now pictures below of 4 gas test before and after adjustment. The engine has a slight jerk at steady speeds the fuel injection and the ignition system will need at least 2 hours of labor to check the problem, ( this is not uncommom for a 914 but can be repaired )
Miscellaneous Items
Technician Notes
Transmission rear mount points on housing itself have apparently been re-welded for some reason either the transmission was out of a car that was potentially rear-ended or there's some clearance issue!, Pic. 1st gear grinds at slow speed down shifts the syncro and or the 1 st reverse slider may be worn.
compression and leakdown test
Technician Notes
Compression and leak down test is fair, number one cylinder was verified at 116 PSI the test was performed twice.
Compressions/leakdown numbers:
1 116 12%
2 132 10%
3 127 10%
4 135 10%
Inspect Alignment
Technician Notes
Our inspection shows your vehicle's alignment is in normal condition at this time.
Inspect Front Suspension
Technician Notes
Looks like all front suspension wearable components have been replaced and struts are powder coated, new front sway bar, Job well done!
Inspect Rear Suspension
Technician Notes
Has new shocks!, Powder coated control arms, axle boots are in great shape!
TIRES-FRONT
Technician Notes
Front tires approximately 80% treadwear
TIRES-REAR
Technician Notes
Rear tires approximately 85% tread wear
Alternator
Technician Notes
13.4 volts and 45 amps, is ok
Inspect Drive Belts
Technician Notes
Great shape!
WINDSHEILD WIPERS (FRONT/REAR)
Technician Notes
Wipers work, blades are getting old.
Dashboard Indicator Lights
Technician Notes
All good!
HEATER
Technician Notes
Works great, heater boxes are ok!
Just listed my 75 2056 on CL.
I want to thank everyone on this forum for the help and support over the years. This restoration took me 6 years to complete, finished in 2016. I've got too many cars and too many kids and I don't have time to drive or maintain this one any more.
https://portland.craigslist.org/mlt/cto/d/p...6937155236.html
The car has about 1000 miles since the completion of the restoration and isn't even broken in yet. I'm happy to answer any questions. This is a really hard one to part with, but it's time.
Youtube walk around at https://www.youtube.com/watch?v=fLYTjKeC8r4...eature=youtu.be
