JimmyT makes some of the best if not the best tools for Porsche cars. I have his hinge pin puller and ball joint socket which is nearly indestructible. He can be found on the
Early 911S Registry. He makes some other very nice tools and equipment.
FS: Door Hinge Pin Removal Tool, P290, 000.721.290.20
This part replaces the NLA Porsche Special Tool:
000.721.290.20 Extractor attachment Qty: 1
It is used to remove 911 door hinge pins:
PET 65-69 911 Fig. 804-00, #03 901.531.305.20 Pin for door hinge Qty: 4
It will not work with the Porsche slide hammer, 000.721.290.00, which currently lists for $264.46.
Instead, it is designed to be used with any slide hammer with M10x1.5 threads. In the US, this would be the $25 Harbor Freight Slide Hammer, #63609. It also works with the previous iteration of Harbor Freight slide hammer, #62959 which was discontinued in August, 2018.
The assembly now includes a threaded extension with a protective nylon sleeve and sacrificial flat washers.
Material: Steel 4140 (42CrMo4)
Heat Treat: HRC 35-39
Finish: Hard chrome
Weight: 252.00 grams
The price is $84.36 each.
Shipping within the US is by USPS Parcel Post ($10.50).
Click to view attachmentClick to view attachment
