Unfortunately, when I disassembled the carbs, I did not take a photo of how the choke ("starter valve") linkage between the two Weber carbs was connected. See attached photo.
I did find a very small cable clamp that looks like it may have been used, but I sure cannot figure out how to make it work.
The choke linkage from under the dash to the left carb works fine - it is to the right in the pic. While the cable to the right carb has a plate (to the left) that it mounts to, I see no way to connect the cable from under the dash to the one going to the right carb - the one that comes from the left in the photo.
I am sure there is an easy way - or parts - with which to do this.
Can someone who has Webers show me how to do this?
TIA!
GN
