jim dorociak
Jul 29 2019, 05:54 PM
SOLD SOLD! I have a late model 911 front suspension available - great way to convert to 911 5 bolt conversion. Includes under body sway bar, both A arms, 911 torsion bars that are 1mm thicker than 914 bars. $600 as it sits - local pick up. jdorociak@gmail.com Jim
DK23
Jul 29 2019, 10:18 PM
Size of the sway bar? Original rubber bushings?
jim dorociak
Jul 29 2019, 10:43 PM
yes original rubber bushings, but front end has not been in use for 15 years. Not sure of the diameter of the sway bar, will measure tomorrow and post. I also have Bilstein 930 struts, new inserts, and 1978 floating rotors and hats and even 993 front calipers available - not pulled yet or priced, but will get posted shortly. I do have a factory 914 thru the body sway bar available as well, again just not pulled or priced. Jim jdorociak@gmail.com
***The sway bar is 21.5mm as I measure it.***
QUOTE(Tdskip @ Jul 30 2019, 09:17 AM)
PM sent on 914 bar
Hello,
Interested in your front suspension! If you still have it I can pick it up today?
Thank you,
Paul
(323) 828-1882
jim dorociak
Aug 4 2019, 11:40 AM
SOLD SOLD Thank you. Enjoyed talking 914's - great project you have got started. Enjoy the journey with your son William. Good luck Paul.
Jim
