Sycolyst
Aug 3 2019, 05:38 AM
Hello all,
First post on the forum after lurking for a while. I am restoring a 73 914 and discovered that the engine cross member sits at an angle towards the back as if the previous owner ran over something and pushed it to the rear. My question...does this cross member naturally have an angle or is it supposed to be straight. I am pulling the engine now and plan to drop the cross member once removed. Any help would be appreciated.
ClayPerrine
Aug 3 2019, 05:46 AM
It should be straight. Someone hit it when driving. You will need new brackets that mount the crossmember to the chassis. The bolt in.
IronHillRestorations
Aug 3 2019, 05:48 AM
Very common to see this, the brackets and/or bar is bent
Sycolyst
Aug 3 2019, 05:58 AM
Appreciate the quick response, it is what I thought. This site is going to be a wealth of information as I proceed. Hope you don't mind the questions to come. Thanks again!!
Aug 3 2019, 07:48 AM
Like Clay said, new brackets. The crossmember can be bent back.
Maltese Falcon
Aug 3 2019, 08:13 AM
bdstone914
Aug 3 2019, 09:43 AM
@Sycolyst You want to replace the two rubber mounts between the bar and brackets at the center. The bolts are probably bent too and may need to be cut .
I sell sets of improved end brackets and hardware for $35 shipped.
I will post the link to that thread later
dr914@autoatlanta.com
Aug 3 2019, 09:54 AM
although we have new outboard solid mounts (the ones that are bent causing the crossmember to lean) you can remove yours, put them on an anvil and beat straight with a hammer and reinstall. Easy and will make the bar mount straight again
bbrock
Aug 3 2019, 10:18 AM
QUOTE(dr914@autoatlanta.com @ Aug 3 2019, 09:54 AM)
+1 That's what I did before sending them for plating.
Aug 3 2019, 10:19 AM
QUOTE(Sycolyst @ Aug 3 2019, 04:38 AM)
http://www.914world.com/specs/tech_engdrop1.php
Sycolyst
Aug 3 2019, 07:47 PM
Thank you. Appreciate the link!
