vesnyder
Jun 27 2005, 06:57 PM
I tried putting on a lug while the tire was already on the car and the other lugs were tightened and the lug got cross threaded - %$#@!! Is there any way to repair these other than go buy the tap and use it once? I tried to insert a lug several times and I could feel that it was not going in right - Any Ideas??
fuch toy
Jun 27 2005, 07:01 PM
Front or rear?
Allan
Jun 27 2005, 07:04 PM
I had it happen on mine as well. I just got a die and chased the threads. Holding so far...
Joe Bob
Jun 27 2005, 07:14 PM
Front's you can replace the rotor, rears thread into the hub which is a little more difficult....bet if Headrage still has that tool and ya ask REALLY nice.....
Or you can use the opportunity to press in studs.....
BTW....have you tried swapping bolts?
bondo
Jun 27 2005, 08:05 PM
I've made a tap out of a bolt before.. Take a spare lug bolt, and taper the end a little. Then take a cutoff wheel on a dremel and cut some slots down the length of the bolt. You now have a tap!
vesnyder
Jun 28 2005, 03:02 PM
It is in the rear!
Bondo - you are the man! I considered this but was not sure it would work!
BTW - the car is coming slowly. My body guy has changed plans, so after I got it taken all apart he decided he wants to do it at his shop? In the process of trying to get it there?
bondo
Jun 28 2005, 04:19 PM
Did it work?
I am in a similar predicament, the soda blasting place is 40 miles away.. I'm going to have to rent a uhaul and coordinate 3-5 friends to carry it on and off the trailer. (it's a bare tub, EVERYTHING is off, so there won't be any rolling going on)
