Is this actually the ground connection on headlight buckets post 1974? I'm used to seeing a stud in this location.
The more I look into this tub, the more I find that the front has been patched together using later model front sheet metal. For instance, I noticed that both front headlight buckets have these connectors where I expected to find ground studs and the entire front panel is from a post 1974 car. Comparing it to some of the other chassis that I have, there are some slight differences to the basic shapes of some of these panels. What should I look out for? Most all my experience is with early bumper cars, and this one I plan to make into an early bumper car. I see that there are no welded in nuts for fog lights or horns on the front panel, but will it all fit since this panel has a slightly different shape. (Or will I need to improvise the shape with some creative body work?) The chassis is rust free and solid other than some previous sheet metal replacement in the front end and one well bent outer longitude that I may attempt to straighten or replace.
Bought this thing many years ago (maybe 12 years ago) in Mason City, IA.
It's time to either put it together or get rid of it. The plan is to flare it and install a 2.7. I have most parts for it in various boxes .....
