My 914/6 conversion with a 3.0, big ports, twin plug Patrick dizzy and MSD, 120/104 web cams, mahle rsr style pistons, 10.5 cr, with fresh 40 webers and a 1-1/2" MSDS headers.
I know I'm leaving power on the table and should get 46mm carbs and a bigger exhaust, but honestly on a narrow body 914 with 205 tires I can already light up the tires in 2nd and 3rd.
Just looking for some jetting advice to optimize the current set-up.
I have 34mm vents, 140 main jets, F3 emulsion tubes, 180 air correction, 55 idle, ported stock manifolds, custom phenolic spacers, K&N filters and rain hats. I have twin O2 meters on it and I'm running 30 degrees total advance. Floats are set and I have 3.5-4 lbs of pressure.
Right now it's running fantastic, almost don't want to touch it, but at 3000rpm cruise and at idle i'm getting about 12.5 AFR and if I kick it down or pull a steep hill at 3-5K I'm a hair over 14.7. I've been slowly reaming the main jets and I'm up to about 140 now. I think I'd like to get it to around 13.5 AFR?
Just keep reaming the mains?
