QUOTE(63acornwall @ Aug 7 2019, 06:16 PM)
The clock does not work in my car , it is located under the main dash in a centre console together with voltmeter and some other gauge .
How do I remove the clock or get at the connections , no apparent fuse ?
The “fuse” is actually a low melt point solder connection inside the clock”. If this is a mechanical clock from an early car, the mechanism likely needs to be cleaned as things gum up over time and eventually blow the internal "fuse". Later models were a quartz drive but still have mechanical parts that can gum up.
http://www.914world.com/bbs2/index.php?sho...35209&st=20See toward bottom of my thread, page 2 for details of how I got mine working.
There is also a very good post over on Pelican if I recall which is where I got basic information when I started messing with mine. Complete restoration by a gauge shop are pricey.
