partwerks
Aug 13 2019, 08:20 PM
Are these those rollers in the guide? Found one in the bottom of the door split in two. Appears there is a roller already in there, or is there more than one in each door?
Click to view attachmentClick to view attachment
Mikey914
Aug 13 2019, 09:48 PM
There are 4 per car 2 on each window. Part of the scissor assembly not sold alone. That's why we made them
https://900designs-container.zoeysite.com/w...r-two-regulator
partwerks
Aug 13 2019, 09:55 PM
I didn't readily see where the other one is located at then?
Mikey914
Aug 13 2019, 10:02 PM
Here
Window base and part 3
jim_hoyland
Aug 14 2019, 05:03 AM
How do you replace them ? I bought a pair for my '75 and Drew a blank when I opened the door....
partwerks
Aug 14 2019, 05:23 AM
QUOTE(jim_hoyland @ Aug 14 2019, 03:03 AM)
I was wondering the same. Maybe it's not as bad as it looks.
Mikey914
Aug 14 2019, 08:43 AM
Actually not too bad. The nylon old ones tend to come off in pieces, but if they don't they can be popped off with a pliers. You can use a pliers to press the new ones on. They will not break, but it takes less pressure if you drop them in hot water for about a minute.
