After having a cruddy day at I work I went out for some much needed 914 therapy. Car was running beautifully (I just changed oil on saturday - castrol 20w50), temps came up to normal, oil pressure normal. I'm heading back to my house (after about 45 minutes of driving) and come to a stoplight. The car slows down but the RPMs go up to 4.5k and hold. It was dark so I couldn't see if the carpet had jammed up under the accel pedal. I fiddle w/ the carpet, try to blip the throttle to see if it is stuck. Something must have worked because just as the light turned green, RPMs came back down to normal idle, but now the engine was running really rough. I'm about 1/4 mile from home, so I ease it into gear and slowly head home. In my driveway, I leave the car running and check to see that the throttle return is working (it is). Idle RPM is normal, but very rough. Engine is 2.0L w/weber 44s & Petronix.
As it was dark and late, I couldn't see very much. A quick search of the forum took me to some posts about problems w/aftermarket accel pedals and cables getting bound up. I'm inclined to think it isn't a problem in the center tunnel (it was running perfectly), but maybe the carpet, or something in the engine bay? I'm not sure where to start or what to look for. Pedals are all stock. Clutch still works fine as far as I could tell. Any advice? Suggestions? I am at the mercy of the Gurus
