I just had (I believe) my Unilite Optical Module fail. I want to make sure I'm testing it right. Off the car I'm doing the following:
12V + to red wire
12V - to brown wire
Test voltage at green wire with the optical slot covered and open (with credit card or the like).
On the green wire I have effectively no voltage. Assuming I did the test correctly, this means it's toast. Which is strange as it's lasted probably 10+ years (I run the 6AL and the protection circuit).
I'm replacing the very expensive 605 module with what seems to be a more cost effective unit, the 6100M. I'd love to test it before putting it in the car, so let me know if I have the procedure down correctly.
Thanks.
