Militant non-smoker here but I'm the kinda guy that if something is supposed to work, I want it to work.
Does it stay in on its own or do you hold it?
I've done a lot of searching but can't seem to find coils - maybe I'm not hitting on the right search syntax.
I'm think I need to check continuity between the coil and the shell...
QUOTE(Jett @ Aug 16 2019, 12:31 PM)
QUOTE(FlacaProductions @ Aug 16 2019, 10:01 AM)
Does it stay in on it's own while heating or do you hold it in?
Mine doesn't heat at all but I have confirmed that power is present in the socket.
I think the coil element may just be mucked up - anyone ever dismantle/clean/repair one?
You can buy replacement coils, but first make sure the connection is clean inside the receptor..
