QUOTE(mepstein @ Aug 17 2019, 09:44 PM)
Perry can make you a quality plug and play adaptor harness.
You have to turn the airbox 180*, use a CIS pump and IIRC accumulator.
I'd use headers from MSDS or Ben's (mb911 ) heat exchangers and he also has an oil tank plus lines, tin is available from Restoration Design, Naro or maddog for a front mount. Rich for the cooler mod and throttle cable set-up, KEP for a flywheel and clutch.
