QUOTE(Mark Henry @ Aug 18 2019, 04:57 PM)
Stock spec, 17-18 pounds. even cross pattern, 1/2 turn at a time.
Before it starts clamping on the disc I do a slight side pressure circle motion with the centering tool, then center it in relation of the fingers.
No loctite, I've never seen an issue, it's not really the bolts holding it on, it's the clamping force.
Thanks Mark, That's what I've done them too. In fact possibly a touch more as my torque wrenches lowest setting is 20 pounds.
QUOTE(mepstein @ Aug 18 2019, 04:58 PM)
This is from kep for the 3.2
@defiantyThat's interesting I hadn't seen that before. I did wonder if it should be tighter as the pressure plate bolts go through the starter ring into the flywheel. 18 pounds didn't seem enough.
