nihil44
Aug 21 2019, 12:39 AM
The wet soda blaster took to the door plate despite my efforts to mask it off and requesting him to avoid the area.
I see 914rubber sells a replacement kit of plate and pins.
As I understand it, the pins are a type of spiral nail. What is the recognised for removal of these and also re installation?
Thanks in advance
<a href="https://s1258.photobucket.com/user/nihil44/media/IMGP3172_zpskajmxihe.jpg.html" target="_blank"><img src="https://i1258.photobucket.com/albums/ii532/nihil44/IMGP3172_zpskajmxihe.jpg" border="0" alt=" photo IMGP3172_zpskajmxihe.jpg"/></a>
nihil44
Aug 21 2019, 12:56 AM
Sorry. Messed up the transfer from Photobucket. Hope this works
defianty
Aug 21 2019, 01:34 AM
I managed to push the pins out from the access hole behind the speaker with a flatted screwdriver. Once I'd pushed them out a little I then pulled them out with a pair of pliers.
Specracer
Aug 21 2019, 03:49 AM
+1, I used a small screwdriver to get it started, plastic body tools to edge each "nail" out further, pliers to finish it if needed. I was able to reuse the fasteners
defianty
Aug 21 2019, 04:14 AM
QUOTE(Specracer @ Aug 21 2019, 10:49 AM)
Yes, I reused mine too. Theyu went in just as tightly as they were originally.
rgalla9146
Aug 21 2019, 05:52 AM
Push or lever the pins out from the back.
Use a razor to lift the plate.
Don't use a plier on the pins.
Re-use the pins
dr914@autoatlanta.com
Aug 21 2019, 07:54 AM
we have the new pins and the badges if you cannot reuse yours, we use a small hammer and dolly to flare the new pins
iankarr
Aug 21 2019, 09:40 AM
QUOTE(rgalla9146 @ Aug 21 2019, 07:52 AM)
Re-use the pins
Palma green metallic is a great color...
rgalla9146
Aug 21 2019, 12:38 PM
QUOTE(cuddy_k @ Aug 21 2019, 11:40 AM)
Re-use the pins
Light Ivory is a far greater more period correct color.
I should get a Karmann tag and stamp it to indicate the current
fabulous shade.
Hey Ian.... looks like rain for tonight.
nihil44
Aug 21 2019, 01:48 PM
Thanks for all the replies.
Your help is much appreciated
David
Specracer
Aug 21 2019, 02:14 PM
I should have said, the pliers are needle nose (small) and you softly grab the main part of the nail (once nail is most of the way out), with out pressure, and then have the outward force on the back side of the nail head.
914werke
Aug 21 2019, 05:23 PM
The fastener is actually a screw so a twisting force will help when installing or removing
