Full Version: Cylinder Head Temp Gauge
Allan
Did a search but didn't find much. I'm looking for good, clear, step by step instructions on installing one. Car has no center console if that matters...........
Mueller
oh yea, adding a question mark to the "subject" would be nice... biggrin.gif I was expecting instructions, not a question wacko.gif
fuch toy
Should be three wires, red power, black ground and one that has a braided end that goes on the spark plug.
Allan
Oops...
lapuwali
If you're talking the VDO CHT gauge, then there are two wires, red and black. They have spade connectors on one end for the gauge, and a white two-wire plug for the other. The sender itself is a ring with braid covering the two thermocouple wires, with another white plug at the other end.
The ring goes under the spark plug, in place of the plugs washer. You need to bend the tab on the ring to clear the plug, but not too far from the plug or it won't clear the head. This ring and the wire make getting the plug back into the engine rather difficult, but it's not too bad if you fool with it for a bit and get the bend right.
Put the sender on the No. 3 cylinder, as it runs the hottest. This is passenger side rear.
The plug can only go together one way, but the spade connectors have to be placed on the right way around at the gauge. If they're wrong, nothing will blow up, but the gauge won't read. There is no +12 connection to the gauge except for the dash lights connection. The gauge is "powered" by the sender.
Running the wires from the engine to the dash either requires you to try to snake the wires down through the OEM rubber wiring thingie that goes through the firewall, or just drill a new hole in the firewall near the rubber thing (use a grommet on the hole).
The gauge should read about 250dF just a few seconds after starting a dead cold engine. It should read 300-ish within 20-30 seconds. Cruising at low speeds should show 275-325dF readings. Cruising at high speeds about 350dF. Pulling up a steep hill about 400dF. All with a stock or near stock engine.
StratPlayer
When you buy the gauge it comes with complete instructions on how to install the gauge, easy install..
bd1308
comes with the A-pillar mounting kit?? I assume not...and the wires reach or do they have to be altered?
d7n7master
QUOTE (StratPlayer @ Jun 28 2005, 04:25 PM)
Strat: thanx. I have the guage - still in the box. But I'm flat out of console "guage room". What a great place to put the most important guage I need to monitor:trophy: Right in my face. So... where do I buy the guage surround???
Ohhh, and what year is your strat?
Strangely enough - I have a strat too - schweet neck - plays like butter.
bd1308
i play the air guitar....need to tune it though.
d7n7master
QUOTE (bd1308 @ Jun 28 2005, 04:47 PM)
bd1308
i think it's just not in the same key with my air piano...
Britain Smith
For my Electromotive set-up, I was just going to use a stock CHT sender and wiring it directly into the computer. What are the thoughts between using a stock sender that screws into the cylinder head above the #3 cylinder or using one of the spark plug senders?
-Britain
Mueller
QUOTE (Britain Smith @ Jun 28 2005, 06:07 PM)
-Britain
the normal CHT is fine for warm up fuel enrichment, not as accurate or sensitive as the under the plug...by the time the regular CHT reads too hot it might be too late unsure.gif
Britain Smith
What is too hot?
StratPlayer
I got the gauge pod on ebay, I think it was for a integra. The fit was great. Don't have to modify the wiring you'll have plenty of wire for the gauge. I play a 91 Strat Ultra, bought it new.
Allan
QUOTE (lapuwali @ Jun 28 2005, 05:00 PM)
So I guess there are no spare wires in the main harness to tie into? I do have a few unused connectors on top of the center tunnel.
bd1308
QUOTE (Headrage @ Jun 28 2005, 07:47 PM)
thats for the center console.....you must run the wiring....
Allan
QUOTE (bd1308 @ Jun 28 2005, 06:49 PM)
So can't I use them if I put in a center console?? Where do the end at the rear???
bd1308
you cant use the center console wiring to wire your CHT guage.... run the wire through the main harness grommet and through the center tunnel and fish it out by the shifter and under the carpet....
Allan
QUOTE (bd1308 @ Jun 28 2005, 06:55 PM)
Why?
bd1308
QUOTE (Headrage @ Jun 28 2005, 07:59 PM)
Why?
it's all tied into the main harness...so its like unusable without hacking through it all. I would think that it would be better just to run the new wiring.
Mark Henry
A lot of the VDO senders came from the factory with the wiring backwards on the gauge...so if yours doesn't work swap the wires.
I found that you must cut a grove beside most sparkplug holes to clear the sender ring even with the bend in it.
Always use it under a plug...won't read true anywhere else.
SLITS
Allan....as I remember, the first part of the wire from the ring under the spark plug is a thermosister wire (don't cut it)and terminates in a spade terminal after 12" or so? It then becomes normal wire to the guage.
Feasibly, if you wanted to lose the oil temp guage, I would think you could use the green? wire that ties into the main engine compartment harness (one used for the oil temp sensor..exits the harness near the battery) and plug into the commensurate spade terminal normally used for the oil temp guage in the center console.
Of course, I could be smokin' some of that "Death Star Gold" too!
The one that I had (haven't reinstalled it yet) had the ring placed under the CHT (engine was carbed though).
type47
use the VDO wiring harness that goes with the gauge. i think the length of the harness is important so don't cut the wires to make it shorter (it's something like 15' long). i suspect for accurate gauge reading, you have to have the full length of the harness to drop the right voltage for accurate measurement.
lapuwali
There are two wires and you must run both of them from the sender to the gauge. Most other types of senders measure the difference in voltage between +12 and ground through the sender (a thermistor, which varies resistance based on temperature) and +12 and ground through a fixed resistance. So, they only need one wire from the gauge to the sender (which then goes to ground through the variable resistor).
The CHT gauges, however, are thermocouples, which generate a voltage themselves based on the difference in temperature between the two ends of two different kinds of wire. One end is soldered together and crimped to the ring terminal at the spark plug. The other ends are in the white plug. The generated voltage is very weak (millivolts), and only works if you measure it across the two wires.
The exact length of the wires given with the harness isn't critical. It shouldn't be WAY shorter (like 1" instead of 15'), nor should it be a lot longer, but it can be half or double the given length w/o throwing off the measurement by enough to matter.
Britain Smith
How come the stock CHT sender is 1 wire? Does this reduce it effectiveness?
How hot is too hot for our type-4 motors?
-Britain
tat2dphreak
QUOTE (Britain Smith @ Jun 29 2005, 03:24 PM)
-Britain
stock CHT isn't for a gauge... it's more like a switch, hot or cold... and is only used for the FI... can't be used for a gauge either, and where it's located, it wouldn't be very accurate...
I say over 350 is getting BAD
Joe Ricard
This thread was going well until the last few posts.
I think 300 is too hot????? Yea right maybe for oil temp.
I personally believe the length of the wires counts as it adds resistance to the circuit. To each his own however.
Stock cylinder head temp sender provides input to the FI brain. works the same as oil temp gauge some degree of resistance/potential to chasis ground.
So what is too hot? Just me again... I slow down when it gets past 350. But that is usually around 95 to 100 MPH during mid day in southtown.
Yup some gauges wired backwards. no reading on gauge at all. I marked Rob Watsons gauge with the color next to the spade on the gauge.
Getting the two wires through the Gooey duck looking thing is a real pain. But it does make for a nice clean appearance. Put it on your to do list while engine is out.
tat2dphreak
QUOTE (Joe Ricard @ Jun 29 2005, 04:04 PM)
DOH! you're right, I had 2 numbers in my head, an shook out the wrong one... I edited my post to correct...
Britain Smith
So for those with aftermarket EFI experience, which type would you use? I am running Electromotive and was planning on using the stock sender...would the spark plug sender work better or does it not really matter?
-Britain
tat2dphreak
QUOTE (Britain Smith @ Jun 29 2005, 05:58 PM)
-Britain
use one under the plug, sender matching the gauge...
Britain Smith
Not sure what you mean, I don't have a gauge?
-Britain
lapuwali
The stock sender is a thermistor (varying resistance with temp), so it only needs one wire. It also pretty much maxes out at about 220dF, which is a function of its location in the head (well away from the plug), and the basic nature of thermistors, which don't do really high temps all that well.
Using it as a warm-up parameter for an ECU is a very good idea, and that's why they used it. No need for a thermocouple amp to get a reasonable signal out of it, and for warm-up use, you don't really need full scale temp. You need "cold", "warming up", and "operating temp". By the time it gets near operating temp, any enrichment added for smooth running during warm-up is down to zero, so readings past that point aren't useful.
Using a thermocouple under the plug CHT, in fact, causes problems with a typical EFI ECU. One, it's the wrong kind of signal, so it needs some electronics to convert it into the range the ECU can cope with. Second, these kinds of CHTs actually warm up too fast. From dead cold on a 50dF morning, a VDO CHT will reach the normal operating temp range within 30 seconds, yet the engine itself won't run smoothly w/o some warm-up enrichment for 3-4 minutes. Oil temp is also not a good measure, since it warms up too slowly (on my 912, oil temp doesn't reach the operating range for 10-15 minutes after a cold start), so the warm-up enrichment would go on way too long. The fast idle control on my '69 Type 3 (w/ D-Jet) uses oil temp to set the idle speed, and it runs at fast idle for a good long time past the engine reaching a reasonable operating temp. On a cool day with no freeway driving, it may NEVER reach a temp high enough to shut off the fast idle.
Another possible temp sensor for aftermarket EFI I've seen used successfully it to take an air temp sensor (as used on D-Jet, but you can use anything, including a commonly available GM sensor), which is a thermistor, and mount it to the head so it hangs below the engine, getting cooling air off the cylinders blown onto it. This appears to strike a good balance between heating up too slowly and heating up too quickly.
toecutter
I have been planning to buy a CHT Gauge for a while. Bus Depot offers a "Cockpit Series" VDO Guage with sending unit for $59.99. They say that it will work with Buses 1960-1991 which, I assume, would be good for a Type 4. This is about $50 cheaper that I have seen anywhere else. Is there any reason this kit would not work?
SLITS
I'm glad I went and looked at mine....it is two wires from the "ring" thru a white plastic connector. Back of guage is labeled + and ground. Until I see a wiring diagram, it looks like the red wire goes to the + (which I assume you also tie into a 12V source and the black wire goes to ground.
Oh well...shoulda paid attention when I took it outta the parts car.
tat2dphreak
QUOTE (toecutter @ Jun 29 2005, 07:04 PM)
same one CB sells for 62... should work great and look almost stock
Jake Raby
The function of the stock CHT boss in the head is NOT where you want to measure CHT with a gauge. Inhave tested this dozens of times and have always seen the same effects. The stock location was used to tell the ECU "Hot" or "NOT" so the engine would not go full rich on start up when its only shut off for a couple of minutes.
The stock boss takes LONGER to WARM up because its away from combustion and also in the cooling fins of the head- by the same token when the engine is turned off those fins soak heat from the chambers and KEEP IT HOT LONGER- so you don't go full rich after being parked for 20 minutes and flood the engine...
In my testing I have seen the stock CHT location be as much as TWO HUNDRED degrees lower temp than the sender under the plug- where it belongs. It seems that the stock sensor will never get above 240 degrees, even when the lead under the plug gets to 400F! By the same token the sender under the plug will cool down to 150F in 5 minutes while the stock location is still at 240.
This is the rule guys:
CHT senders for gauges GO UNDER THE SPARK PLUG- No where else! AND I don't care if you think its a big inconvenience to work with when you pull the plugs out or not! I have a racer that melted a head because he refused to listen, was hard headed and has since changed his mind.
The stock sender location is used ONLY FOR EFI sensors- PERIOD! If you hook it to a gauge you may as well throuw the gauge out the window because you are wasting your time and possibly baking the engine and thinking you are just fine! Another racer kept having valve issues with the engine from his "Other" builder and told me his heads never got over "300F" I asked where he measured it and of course he said "Stock location"... I scolded the hell out of him, got him on track and he found that his gauge was reading 450F all the time! We found the source of his heat and the valve issues ceased.
As for temps... Here are my standards ALL MEASURED UNDER THE PLUG!
275-350 perfect for flat line driving
350-375 OK for climbing the occasional hill or for engines that are driven in 5th gear BELOW 3500 RPM- DO NOT DO THAT IN A TEENER!(people wonder why 2.0 heads crack)
375-400 Very warm- don't sustain these temps for more than a few seconds.
400+ You are aging the heads, startsing cracks and waiting for a dropped seat followed by the opening of your wallet.
NO 914 engine should run higher head temps than 375 climbing a hill, if yours does- You have a tuning/configuration issue that needs special attention ASAP!
With all that being said, my 3 Liter 235 HP engine runs 275-300F and will hit 325 climbing a hill....(DTM cooled)
The 2316cc Hybrid engine (180HP) in the teener runs a SOLID 275 and has NEVER went over 300 in the past 8300 miles that I have been driving it.... (DTM cooled)
So, with that being said I'll say that most stock 2 liter engines with stock cooling run hotter than a well tuned and configured performance engine- The average I have observed in my car was 350F all the time with a bone stock 2.0. A Performance engine doesn't run hotter- It just HAS to be correctly tuned.
BTW- Volume 5 of the new handbook series is "101 tips to keep your Type IV engine running cooler" and it will go over all these things in detail along with preventive measures, theory and tons of plots from the datalogger to illustrate the subject at hand... Patience, patience....
tat2dphreak
what do you mean by this Jake?
sorry, it's early and you lost me on that line. I sould think it would be opposite, keep the revs below 3500 in 5th
Joe Ricard
QUOTE (tat2dphreak @ Jun 30 2005, 05:37 AM)
I prefer 4000 in 5th.
Keeps ma hair on fiar. 4200 in 5th is great 4400 and you are going to jail if they catch ya. mueba.gif
Britain Smith
Jake...do you sell the CHT gauge and sender in your type-4-store?
If not, does the one from CB performance come with the 15' extension wire?
-Britain
StratPlayer
I believe all the vdo cht gauges comes with that much wire, I know mine did.
Jake Raby
The resolution of the VDO gauge does not require a special extension wire. I have compared results with the same gauge by hooking it direct or through a 20 ffot lead wire. The speed and accuracy was spot on either way and repeatability was better than expected.
I only sell Westach and SPA gauges in the store- not VDO gauges. The SPA and Westach do require the special extension wire.
What I meant by saying that 5th gear kills engines is this:
Your car weighs the same in any gear- remember that. As speed increases and aerodynamics effect the vehicle and you continue to gear up as you shift load is increased on the engine. Since the car weighs the same and load increases more heat is generated simply because load= heat.
When you couple this fact with the fact that the engine is aircooled and the fan driven at 1:1 off the crank things get more interesting. This is because in a lower gear the load is still present or even multplied and with a lower engine RPM the cooling fan is less efficient in producing volume and pressure to get the air to the hottest parts of the engine. This heats heads up fast! Since most people are cruising around at this low RPM in 5th sooner or later they have to hit 4th or even 3rd gear . At this time the load is decreased and a burst of cooling air blasts over the heads with high pressure and volume- Voila, now you have a cracked head and have added yet another insane heat cycle to your cylinder heads.
This is so common with 914s that we are seeing more and more heads that have been so thermally cycled that they are junk and can't even be welded on safely to be repaired.
So the moral of the story is that RPM is your friend- use it. DO NOT run your engine at less than 3500 RPM in 5th gear or you are killing your heads. I shift into 5th at 4200 RPM and don't run in that gear below 3800 in my car- even with exceptional DTM cooling. Lower revs and high gears also kill oil pressure and increase rod bearing wear through point loading.
Anyone on this list can do the same tests I have with a cheap CHT gauge and some attention being paid to the results... Run this engine like it were an airplane- If its not turning somethings burning!
Britain Smith
Jake...I have searched your store every way that I can think of and I still cannot find the gauges. Help Please.
-Britain
Jake Raby
Britain,
The gauges are not on the store site just yet. I have only recently decided to sell them through the store and I'm still awaiting my stock order.
I have a dual CHT gauge that is very nice and monitors botjh heads at one glance. I also have another dual gauge that has oil temp and head temp in the same unit as a dual as well.
bd1308
jake any update on the guages?
JmuRiz
I'd like to know as well, my VDO CHT sender must be off becasuse my temp never gets into the 200's...might as well get a dual gauge when I replace.
FYI: The R.A.T compound had a power surge the other day and a lot of the computer equipment got fried, so the type4store etc might not work quite right.
lapuwali
QUOTE (JmuRiz @ Aug 3 2005, 10:11 AM)
Where do you have the sender mounted on your VDO setup? The sender itself is cheap ($15-20 from aircooled.net). Have you tried swapping the leads at the gauge? The "rest" position on the gauge is usually 150-200dF, so it's possible you're not getting any reading at all.
JmuRiz
OK, I'll look into a new sender...I thought that the resting place would be far-left. I'll check my setup and get a new sender and hopefully that'll fix it. Thanks!
