1973 Signal Orange 1.7L with odometer reading of 81k miles. True mileage is unknown. This is a fun car to drive. It looks nice but could use some work. This has been kept in a garage since I bought it. Best way is to list with pro’s and cons. My intent is to show you the good and bad, then you can decide if this is the car for you. I’m selling this car because I don’t drive it that much and bought a new car.
For sale at reduced price of $6,000 or best reasonable offer. My plan is to offer it here first and then off to ebay in the near future. Here is a link to more pictures: https://flic.kr/s/aHsmGupkts
Pro’s:
Exterior paint in good condition
New front brakes
Back brakes in good condition
Fuel pump relocated to front compartment to prevent vapor lock
Fuel lines replaced
Replaced 3 out of 4 wheel bearings (4th in good condition)
New tie rod ends
Tune up done 3k miles ago that includes new oil and filter, adjust valves, set timing and 4 wheel alignment
Has stainless steel heat exchangers
Has side shift transmission
“Hell hole” has been repaired
Longs have also been repaired
Replaced many rubber parts like dash to windshield seal, trunk seals ect.
Replaced rear taillight lens
Original fuel injection
Registered and passed safety inspection
Now the Con’s:
The big rust areas are trunk, bottom of both doors, also door sills
Rear defroster does not work
Fresh air fan does not work
Heat does not work (missing parts)
Driver’s side window does not line up properly
Engine drips small amount of oil when parked
Front dashboard has cracks and has cap on it
Gas fuel sender works on half tank or less of fuel
Drivers side outside door handle does not always work
