It appears they're not metric and therefore I'm lost
Ideally I'd like to get some wingnuts but M5 are too small and M6 too big.
Does anyone know the correct size? Thanks.
[/ur
jd74914
Aug 28 2019, 05:16 PM
What's the thread major diameter? Likely a 10-24 if M6 is a little too big.
defianty
Aug 29 2019, 01:16 AM
QUOTE(jd74914 @ Aug 29 2019, 12:16 AM)
@jd74914 My vernier caliper says 0.206". Thank you.
defianty
Aug 29 2019, 04:47 AM
A bit more research and with the help of an engineering friend we've found that the thread is UNC 12-24. My chances of finding a wingnut in that size in the UK are going to be slim.
jd74914
Aug 29 2019, 05:24 AM
Wow-didn't even consider that since almost no one in the US uses #12 screws either.
defianty
Aug 29 2019, 06:33 AM
I've managed to find a source in the UK. They're made to order though so I'll just have to wait a couple of weeks. Fortunately they weren't expensive.
sixnotfour
Aug 29 2019, 07:49 AM
Mark Henry
Aug 29 2019, 08:38 AM
Problem is wing nuts will back off from vibration, that's why they come with nylocks. I'd use some light duty loctite (purple, loctite 222) on the wingnuts so they won't get loose all the time.
