@914Sixer is right, pretty easy. Even the Speedos are not hard, but can be a bit of an aggravation.
Fuel gauge is easy to test with resistors. ) full, 90 empty, sweep between the two moves the needle.
Most of the time, a bulb has fallen out that makes the rattle.
Speedo the gears fail. Atach the shaft to a Dremel, and the proper sized square bit, and you can spin it fast enough to test to see if everything is moving.
Plastic for glass.
Trim Black is better than Gloss unless your into that sort of thing.
Not hard, bellow in my sig is how to take these part and put them back together again. If it is not I have written enough on the subject that it should not be hard to find the ramblings of this
Seattle Speedo is doing very high end builds now,
they do great work, you will see them photographed in tons of builds on high end 911s that where reimagined. And if I did not know how it was done, I would give them my business.
