QUOTE(orangecrate @ Sep 2 2019, 07:53 PM)
Ah I love learning new things. So , in essence , trying to make a 1.7 anything other than a 1.7 is fruitless. It's dialed in as a package. In my position , that's good to know. Makes my decision easier to make. Thank you Gentlemen. Fix the crank. Vroom Vroom
If you are taking it apart anyways you could get a 96mm P&C kit (1.7 heads would need to be machined) and take it up to 1911 and add a d-jet compatible performance cam. You might be able to squeeze an extra 10hp or so out of it. You could probably tweak the 1.7 d-jet to handle that without issue though as stated previously 1.7 intake and throttle body will most likely be your limiting factor as they are really tiny. I have first hand experience with this as I did a Megasquirt build for someone where we wound up using a 1.7 intake on a stock 2.0 motor and the throttle response was noticeably impacted. The 1.8 intake is a much better starting point as the intake runners are the same diameter as a 2.0 and the throttle body is larger as well. Theoretically that intake should be able to handle ~140HP maybe more but it would also require a little fab work to mount of the d-jet sensors. Bottom line a stock 1.7 isnt the best place to start to add performance cheap.
If I were you I would consider the following options:
#1 Cheapest - Tear down your 1.7, fix/replace the crank, add a d-jet performance cam, use your existing d-jet and be on your merry way.
#2 BUT Given you are looking at a rebuild anyways, 1.8 cores are a dime a dozen (ive seen people give them away) and are a better starting point for a 1911 build. The heads have larger valves, no machine work needed to accept 96mm P&Cs and the 1.7 intake is bolt on (2.0 heads have a different bolt pattern) Find a good 1.8, add 96mm P&Cs and a cam if you feel like splitting the case, run it with your d-jet setup, or even better find one with the 1.8 intake included and adapt that. May not even cost much more given the damage in your 1.7 is currently unknown.
#3 Get the 2.0 and source an appropriate intake and injection setup ($$$ and will only net you maybe ~15hp over the 1.7)
#4 Commit, and just build a 2256 with Megasquirt
I dont know what your overall goals/priorities are but after 20 years and 10+ 914s at this point if I was looking at tearing into a motor I would just go option #4. D-jet is a great system but you open up whole new worlds once you get into fully programmable fueling.
