Full Version: idle air controller/idle air valve?
second wind
Car is a '73 2.0 with d-jet and forward mounted fuel pump. Idle disappears after hard driving or freeway/uphill driving. Any ideas out there? Is this part serviceable or replaceable? Do tell....thank you.
gg
iankarr
Not really sure what you mean by "idle disappears".
second wind
QUOTE(cuddy_k @ Aug 31 2019, 05:39 PM) *
Goes from 900 rpm to zero rpm.....car will stall at stop light if I don't baby the pedal....
Thank you for reply,
gg
sholman5
What is your cold start rpm. Should be around 1600. AAR should be open allowing more air into the plenum. Do not set your idle at cold start.
ChrisFoley
914s don't have an idle air controller.
sixnotfour
decel valve plumbed wrong ????
second wind
QUOTE(ChrisFoley @ Sep 1 2019, 11:03 AM) *
That's what I thought.....thanks Chris. I'll set the idle when it warmed up and see what happens.
gg
sholman5
Take it out for a drive for about 30 miles or so, when you get back set the idle speed.
