QUOTE(Jett @ Sep 8 2019, 11:04 AM)
What is the downside of having the wrong type of CHT?
So, while this should probably be in The Garage, a bump for this.
Really, why does it matter what the resistance is, if we're effectively going to wreck its designed function with a spacer to slow down the drop in resistance?
There's two CHT sensors:
per Paul's specs, 0 280 130 003 for the 1.7 and 0 280 130 012 for the 2.0.
Normal Value(s):
0 280 130 003 and 0 280 130 012: about 2.5 K ohms at 68 deg. F, less than 100 ohms with hot engine.
0 280 130 017: about 1.3 K ohms at 68 deg. F, less than 100 ohms with hot engine.
The function of the CHT is to "tell" the ECU that the engine is cold, please richen the fuel. This happens at higher resistance. Both are the same value when hot ("less than 100 ohms") so the wrong CHT doesn't matter after warmup.
By adding a spacer, we're slowing the conduction of heat to the CHT< keeping the resistance higher, longer.
Therefore...if we install the 2.5K ohm sensor on an engine that needs the 1.3K ohm sensor, then it keeps the car richer longer, but ends up in the same place once the engine is hot (and reducing the need for the spacer).
If we install the 1.3K ohm sensor on an engine that needs the 2.5K ohm sensor, then it leans the engine sooner, but ends up in the same place once the engine is hot. But that can be compensated by installing the spacer.
So where's my disconnect here?
