FlacaProductions
Sep 8 2019, 11:09 AM
Done a lot of reading on old threads here and have found that sizes for the bolts on the bottom of the rocker covers are 6MM X 12 (or 16 mm long) and the two screws in the fender well are #8X3/4 - but I can't find reference for a sheet metal screw size if you switch from rivets across the top...
Thanks!
North Coast Jim
Sep 9 2019, 06:14 AM
QUOTE(FlacaProductions @ Sep 8 2019, 01:09 PM)
Thanks!
Use the rivets. I used pop rivets. The standard aluminum ones. Wrong color of course so I colored them with a magic marker. Looks good.
JOEPROPER
Sep 9 2019, 07:05 AM
QUOTE(North Coast Jim @ Sep 9 2019, 08:14 AM)
Thanks!
My '75 had aluminum rivets, which were perfect. My other '75 has bolts, which will be replaced with rivets.
mlindner
Sep 9 2019, 07:37 AM
I did two 914's at work and had some problems. One, holes sizes all over the place.....two fiberglass rocker will crack out using rivets. One of the cars and mine at home I used the black screws that have a collar around them. Looks a little bigger but works really well. Not sure of the size, will have to buy a few and test. Best, Mark
Spoke
Sep 9 2019, 07:44 AM
I got several sizes of metal screws and used the ones that fit. #6 or #8, 3/8 inch. As long as the head doesn't interfere with the door you'll be ok. You can file down the head if too tall. I don't like the rivets as it makes it difficult to remove the rocker panels for quick clean outs. The 914 was a low budget car thus pop rivet the rockers and weld on the muffler heat shield.
dr914@autoatlanta.com
Sep 9 2019, 08:37 AM
too many have wallowed out the rivet holes in the top unfortunately necessitating larger rivets or screws, use the factory plastic rivets like previously stated if you can
FlacaProductions
Sep 9 2019, 12:02 PM
Good info/input here - i was thinking screws for quick/easy cleanouts like
@Spoke mentioned (and I don't have a rivet tool....) but maybe I'll get the rockers off and see what's underneath and the condition of the rivet holes and see what's what....
Mikey914
Sep 9 2019, 02:58 PM
Got the pop rivets in black if you need them
https://900designs-container.zoeysite.com/r...black-aluminum-The screws are the cheese head ones like the engine tin use. I use the stainless allen screws as they are easier to remove and you don't see them have those also if you need them
https://900designs-container.zoeysite.com/e...nd-washer-set-1
enf2232
Sep 9 2019, 05:44 PM
Just did mine - fiberglass. Used standard pop rivets, steel, 1/8" size x 1/4" grip,
PCH
Sep 10 2019, 03:44 PM
Put new metal rocker panels on the car. Forgot to drill out the holes prior to painting them. Marked where the drill holes are suppose to go. Then decided to see if it actually needed to be plastic riveted (exactly how strong are the plastic rivets anyway?).
So far so good. It looks like those plastic rivets aren't needed after all.
Does anyone have any experience not using fasteners in the top of the rocker panels?
bobboinski
Sep 13 2019, 08:54 PM
QUOTE(Mikey914 @ Sep 9 2019, 01:58 PM)
https://900designs-container.zoeysite.com/e...nd-washer-set-1 Pop rivet link doesn't work for me.
Sep 13 2019, 09:09 PM
Porsche used plastic rivets so you could remove them with a razor blade and not have to drill them out.
FlacaProductions
Nov 19 2019, 09:07 PM
Getting things together to take off the rockers and see what's what under there and make sure things are clean etc. - I have the rocker kit/rivets coming from
@Mikey914 - suggestions on what rivet tool to get. I have no clue on this one.....
914forme
Nov 19 2019, 09:17 PM
Any will do in reality, if doing a lot of them high quality air riveter, if doing a 914, most anyplace will sell one. If you need an idea
HERE
FlacaProductions
Nov 19 2019, 09:18 PM
Ah. Got it. Thanks much. Funny - never been around one so I didn’t know the details as to how they handled different size rivets. I get it now. Cool.
TonyA
Nov 20 2019, 08:37 AM
QUOTE(mepstein @ Sep 13 2019, 10:09 PM)
What gun do/did you use for the plastic rivets? I got some plastic rivets a few years ago and the stem seemed to be to short for any of my rivet guns and also to thin to grab.
Mikey914
Nov 20 2019, 10:46 AM
QUOTE(bobboinski @ Sep 13 2019, 06:54 PM)
Somehow that didn't make it to the new site
https://900designs-container.zoeysite.com/r...lack-aluminum-1Cheesehead
https://900designs-container.zoeysite.com/c...ead-screw-set-1Sorry old post
914forme
Nov 20 2019, 02:56 PM
QUOTE(TonyA @ Nov 20 2019, 09:37 AM)
Most of them are meant to be driven in to expand the fingers and not pulled out. Short pin is a sign that it goes into the rivet and expands the fingers.
wes
Nov 20 2019, 10:28 PM
I used aluminum rivets and every time I open the door that’s the first thing I see. Are these the type of rivets used?
falcor75
Nov 20 2019, 11:51 PM
I've got plastic rivets at the top and M6 screws on the bottom. Makes it nice and easy to remover the rockers when needed.
FlacaProductions
Nov 21 2019, 06:06 PM
@914forme - ordered that riveter - thanks.
