Not a show car, but a nice Sunday Driver. I’ve never driven it more than 500 miles in a year, and usually much less. Probably less than 5,000 miles since I bought it.
harveyhoover@comcast.net
610-269-1075 – Leave Message
* 2056 with cam and Webers
* 2 Liter heads
* Bilstein shocks and strut inserts
* 914-6 rear springs (80 Lbs.???)
* 19mm front sway bar with factory linkage
* Stock 16mm rear sway bar
* New (4/2019) Rear main Seal and Flywheel / Clutch / Pressure Plate / Throw Out Bearing assembly
* Recent (mileage wise) engine rebuild
* Mahle alloy wheels (5)
* Longitudinals and jack posts replaced
* Crane Hi-6 multi-spark box with PS91 coil and Pertronix point replacement
* Recent new alternator and solid state regulator
* Relay board cleaned and all connection points soldered
* SSI heat exchangers
* LED running and instrument lights
* Bronze pedal cluster bushings
* Recently repaired odometer shows 82900 but real mileage unknown (Operated intermittently when I bought the car)
Also Included:
* Restoration Design panels for engine shelf repair and new battery shelf
* Parts accumulation for under trunk external oil cooler
* Parts accumulation for deep oil sump
* Various parts for original fuel injection system. Brain, manifolds, throttle body, injectors with wiring harness, etc.
* Original Porsche crest steering wheel (Aftermarket wrapping, don’t know what’s under it)
* Repro 916 front bumper
* Weltmeister short shift kit (Tried it, didn’t like it.)
* Miscellaneous seals, gaskets, ignition parts, etc.
* 20+ years of 914 related magazine clippings
* Haynes and Clymer Workshop Manuals
* HP and Bob Tomlinson Weber Manuals
* Other 914 related books and literature
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachmentClick to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment Click to view attachment
