911 2.7L Engine
Listed on ebay: https://www.ebay.com/itm/223657958862
I will give registered 914World users a 15% discount.
Complete 2.7L engine from 1974, serial number 6142439, 7R case. The engine is torn down waiting for a rebuild as a result of my stalled 914 transplant. I am moving and don’t have room in my new home for a workshop.
This is the most desirable of the 2.7L engines with 1974 being prior to the use of thermal reactors and having the 7R case.
The engine was removed from a 911 a number of years ago in working condition and was replaced by a 3.2L engine. I purchased the engine 3 years ago to rebuild and transplant into my 914.
Prior to removal from the donor 911 the engine was rebuilt, the crankshaft was Magnafluxed and polished and case inserts were installed. My teardown discovered one broken piston compression ring on cylinder #6 with a minor scratch in the cylinder wall. The cylinders are the preferred nikasil coated type.
The engine is complete with all parts, labeled nuts & bolts, labeled cylinders/pistons/piston pins. It also has 1.5” headers (one will require minor repair for a crushed tubing bend).
It also will include the full CIS fuel injection system, flywheel, clutch and pressure plate. Finally included is the engine tin and engine mounts.
