Full Version: Bizzar Running problem
Eric Taylor
Alright guys, so today was a beautiful day on the coast. I had a really really good drive maybe 100 miles or so half of which were twisties biggrin.gif . But a couple of times the car wanted to die like it lost spark or fuel. I had to pull over once, and I could hear the fuel pump running and but it was idiling funky and running poorly it then died, but fired right back up and ran great. Later on in the final half mile home, it ran really crappy, back firing, idiling low, and black smoke. It was really strange because it would only do this for a few seconds and then just run like a top, idle great, good power, and generally running well. So I don't really know what to think. I'm thinking it's losing spark or fuel momentarilary and then coming back some how. Oh and it's getting terriable milage, like 15mpg from a 1.7. One idea that I had was a weak coil that wasn't sending a strong enough spark all the time, and sometimes intermitent, but it's just an idea I might just be sheeplove.gif with that one ( Always wanted to use that emoticon smile.gif ). What do you guys think?
Eric
goose2
Hmm...black smoke, bad mileage...you're getting too much fuel intermittantly. Do you have the original fuel injection? If so, it might be the CHT sensor (cy. head temp.) You can just unplug it after warming up the motor to test it. If the problem goes away that was it. About 20 bucks for the part but you need a special tool to change it (easily made yourself ig you have a grinder and an old socket wrench extension you can sacrifice). If you have carbs....could be bad needle and seat, sticking float, too much fuel pressure.
bd1308
i hear if you unplug the CHT even when hot the engine wont run...actually i;ve done this by accident and it died.
goose2
Yes, you may be right beer.gif Have to admit I don't remember without looking it up. When the motor is at full operating temp...the sensor either has no resistance, or infinite resistance. If no resistance...then you'd have to connect the sensor wire to ground rather than just unplug it. This was a test to see if you were paying attention wink.gif ...you passed with flying colors smilie_pokal.gif
Seriously...sorry if I mislead you Eric...better check the manual or wait until someone with a better memory chimes in.
McMark
agree.gif CHT wire grounding intermittently. Check there first.
Eric Taylor
I've got a pretty new CHT in their but always worth a check. So whats the proper method?
Eric
goose2
headbang.gif Well Eric...wrong again...how embarrasing! There's a great site by Paul Anders dealing with D-jet FI at :
http://members.rennlist.com/pbanders/DJetParts.htm
Here's his section on the CHT sensor:
Function: Senses engine temperature and sends signal to the ECU to provide mixture compensation. Proper part for your application and proper functioning is extremely important!
Normal Value(s): 0 280 130 003 and 0 280 130 012: about 2.5 K ohms at 68 deg. F, less than 100 ohms with hot engine.
0 280 130 017: about 1.3 K ohms at 68 deg. F, less than 100 ohms with hot engine.
See Notes section below for more data on the resistance vs. temperature values of these sensors.
Failure Modes Open: The ECU interprets an open sensor as a signal to greatly richen (e.g. I've measured an over 3X effect) the mixture. This usually makes the car impossible to start and causes it to stall if the sensor fails open while running. Check by disconnecting the sensor from the wiring harness and measuring the resistance to ground, refer to the values above. Shorted: The ECU interprets a shorted sensor as a signal to lean out the mixture (about 30% leaner). The car may run and start in this condition, but will have poor idle and drivability. Check by disconnecting the sensor from the wiring harness and checking the resistance to ground. Note that shorts are often intermittent, caused by nicks in the sensor wire and by exposed contacts to the wiring harness touching ground. Check by inspection.
Stuck Value: I've heard of at least one case of the sensor being stuck at a value (e.g. 50 ohms) and not varying with temperature. Depending on the value it gets stuck at, it can result in either poor cold or hot performance, or both. Check by measuring with an ohmmeter as described above.
Mismatched: The 1973 2.0L's came with the 0 280 130 017 head temperature sensor, 039 971 762 A ballast resistor, 0 280 100 037 manifold pressure sensor, and the 022 906 021 E version of the ECU. This set of components must be used together. Any substitution will result in idle and part-load performance problems, and possible poor fuel economy. Additionally, use of any of these 1973 2.0L components with a 1974 2.0L setup will also cause problems. See the table above for the suggested setup for both 1973 or 1974 2.0L engines. If you have a 1973 2.0L and you want to keep the original setup, make absolutely certain that you have the correct combination of components. The 0 280 130 017 head temperature sensor's cold (70 deg F.) resistance is about 1200 ohms, compared to 2300 ohms for the 0 280 130 003 and 0 280 130 012 sensors. Use of the ...017 sensor with the 039 906 021 ECU (1974 model) will result in a lean mixture during warm up, causing low idle and/or backfiring on over-run. Use of the ...012 or ...003 sensor with the 022 906 021 E ECU (1973 model), with or without the ballast resistor, will result in a rich warm-up mixture. Take the extra time and determine exactly which head temperature sensor is installed in your car and make sure it matches the setup.
Notes: This resistance of this sensor is one of the primary factors in adjusting the mixture and it has a strong effect. An additional issue is the availability of the 0 280 130 012 sensor. I have found this sensor difficult to locate, and most shops substitute the 0 280 130 003 sensor for it. As far as I can tell, it is either exactly the same or nearly identical. Bosch even lists the ...003 sensor as being cross-referenced to the Porsche/VW part number 311 906 041 A. See the entry above for the intake air temperature sensor for theory on how these sensors work.
Installation Notes: Installing this sensor can be tricky. The best solution I've found is to buy a deep 13 mm socket and a 3" extension (I bought mine at Checker, about $5 for both). Use a Dremel tool with a cut-off wheel to cut off one of the corners of the four-sided end of the extension (the part that goes into the socket) to create a gap that the sensor wire can be threaded through. ALWAYS USE SAFETY GLASSES when doing this kind of work with a Dremel tool. Filing works, too, but it will take a very long time. Make sure to use the copper washer that comes with the sensor - the washer assures good thermal conductivity to the head and prevents loosening. Keeping the washer from falling off during installation can be difficult. First, to keep the sensor from being pushed back into the socket during installation (which will pop the washer off, and it'll fall into the head air fins), position the sensor so that it's sticking out a bit, then tape the wire with a single loop of masking tape to the extension. The wire will resist the sensor being pushed back into the socket. To keep the washer on the sensor, I use a couple of tiny drops of superglue to hold it in place. The glue bond will be broken when the sensor is tightened. DO NOT overtighten this sensor, just get it snug. It's easy to strip out the head threads and then you'll have to pull the engine to fix the problem.
More Data!!: Below is some characterization data I took on each sensor at three different temperatures (one data point missing). Note that these are representative readings - there is significant manufacturing variation in these sensors. All data measured with a freshly-calibrated Wavetek LCR55 meter.
Sensor Temp = 39 deg. F
(ice bath with thermometer) Temp = 61 deg. F
(room temperature)
Temp = 210 deg F
(boiling water at 1000 feet altitude)
0 280 130 003 6.10 K ohms 2.94 K ohms 199.3 ohms
0 280 130 012 NA 2.85 K ohms 191.2 ohms
0 280 130 017 3.63 K ohms 1.74 K ohms 124.7 ohms
goose2
Thanks for catching my error Britt...I'll shut up now
bd1308
i'm not stepping on your toes man. I mess up all the time. Ask Miles.....
Eric Taylor
Thanks randy see you later.
Eric
Eric Taylor
We'll guys I just got back from the tropics and got a chance to test the cht. I drove the car for maybe an hr and when checked using the battery as a ground, got no resistance. What does this mean? I'm not real sure from the info provided weather this is good or bad. Anyway hopefully it's bad and the CHT is my problem.
Eric
redshift
QUOTE (bd1308 @ Jun 30 2005, 07:51 AM)
Yes, BRITT SCREWS UP ALL THE TIME.
Miles
redshift
QUOTE (Eric Taylor @ Jul 19 2005, 11:21 PM)
Eric
Sounds like it's dead, or you have mistakenly measured.
Nothing at all? It's dead.
M
Eric Taylor
It takes the ohm meter to 0 ohms when I test it. Resting point for the meter is 1k ohms.
Eric
lapuwali
Measured from where to where?
You should try unplugging the connector and measure from the sensor side of the connector to any ground point (the head is actually better than the battery for this). You should see some resistance all the time, even with a hot engine. With a cold engine, you should see a high resistance (> 3K ohms). If you see 0 ohms here, you have a dead sensor.
If this appears to work, then it's possible you have a bad wire from the sensor to the ECU. Check it for broken insulation, and repeat the meter test at the ECU end of the wire (you'll need to unplug the connector from the ECU). If you get 0 ohms here, you have a shorting wire.
Eric Taylor
We'll guys I've got the new CHT in and it's doing some, but still it's not getting good milage, and it's having issues reving and developing clean power, their is a hesitation when driving at times and I'm really just running out of ideas on what to do.
Here is what I have done
- New proper Vaccum hoses
- New Trigger points
- Timing
- Tested replacement MPS from Geoff
- New CHT
- Resealed the throttle body
- New TPS, recently calibrated.
- Tested and properly running fuel pump
- Good and accurate fuel pressure
- New Bowlsby FI Harness
- New Plugs, cap, rotor, points, and wires
As you can see i've done almost everything that one could think of and to be honest I'm extremly discourage as it seems that I've really got no more ideas for what to do with this car. The thing is that I can drive it as it idle's very well and very cleanly no change, and if you don't get on it to much and have deep pockets you can drive it all you want as the gas will eat you alive like a cheby truck of sorts. Anyway these are the last couple of things I can think of.
- Coil
- Valve Adjust
The valve adjust will be done this week prefessionally, but I don't honestly see it having a large effect on the problem, but what do I know at this point? Anyway help me guys, I love the car but this is going on 2 years of little crap so that you can't reliably drive i. sad.gif
Eric
goose2
Eric, sounds like you've covered just about everything. Your poor fuel mileage suggests it's running very rich. This is D-Jet FI Right? Any black smoke? Is your tailpipe real sooty? Are your plugs black after a high speed run? Any vacuum leaks will make it rich. I'd check the manifold runner to head joints, the runner boots, the throttle body to manifold seal (again), and any and all hoses and connections. Bring it by my shop if you're in Eugene, I'll have a look.
Eric Taylor
Randy it's got all those signs, but I really just can't figure out exactly what it is. I've been throught the vaccum run around a million times by now, any tips on how to do it?
Eric
Rand
What about the MPS? I'm wondering if the MPS vacuum or diaphragm is bad, thus causing it to run maximum rich at all times. At an idle, if you pull the vacuum hose off the MPS, does the RPM or anything change?
--- oops... now I see you already tested the MPS... still curious if it changes when you pull the hose off while running though.
goose2
How did you test the MPS? Do you have another you can plug in to test? We've got some spares at the Eugene shop if you want to try one. One way to find a vacuum leak, although I hate to recommend it, is to spray something around all the possible sources and watch for a change in idle speed or exhaust smoke. I've used WD40 and carb or brake cleaner. BEWARE of squirting flammable liquids around a hot motor though...the stuff will vaporize and create a big fire hazard and nasty fumes you don't want to inhale. Valves way out of adjustment could theoretically cause a rich condition by causing a decrease in vacuum, but I've never experienced this. A bad ecu is possible but a VERY long shot.
redshift
Eric, depending on how rich you are running..
You need to stay on top of oil changes, if you are driving the car, and it's running that rich... rich running washes the oil off the moving parts, sooner than you'd think.
I may mean 1000-1200 miles.... but if it's real bad, it may be 100-200 miles.
M
SGB
um...
check the plugs? Maybe one is fouled?
redshift
If you pull the air box, and your intake looks like the exhaust, your plugs are fouled.
M
