QUOTE(Superhawk996 @ Sep 12 2019, 06:52 PM)
Mark,
I'll want mine restored nicely.
I’m waiting on some inner spacers from 914rubber. Mark said it will be a couple months. While the outer trim rings seem to hold up great, the white inners, especially the early ones, turn into dust. It’s also surprising how many decent mirrors you need to make one good one.
Problems:
Someone used a screwdriver to pry off the trim ring and cracks the edge
Someone tries to adjust the mirror when it’s corroded tight and the inner washer makes a bulge in the stainless cover.
Rock strikes to the stainless cover.
The large triangular washer inside the mirror is cracked or broken in half
The chrome is chipping or corroding on the arm.
It can take two or three mirrors to make a good one. The ones that won’t work for a restoration (dented backings, peeling chrome, etc) I will probably powdercoat in black.
So once I get some inner spacers I will build up a couple to offer up.
