QUOTE(sportlicherFahrer @ Sep 15 2019, 05:39 PM)
My GUESS is that due to the hydraulic lifters you get some compression on your exhaust stroke because the lifter isn't pumped up. If it was fully pressurized you would get less compression on the exhaust stroke because the valve would be opening sooner.
What do you have your valves set to? 2 turns in from 0 lash on compression stroke?
Yes from an instructional article I read from Richard Atwell on VW type 4 engines he recommended between 1-1/2 or 2 turns after zero lash. But I’m recalling also hearing you tighten the adjuster until you fell the spring compress all the way then back off a turn?
