Full Version: case cylinder hold down bolts
jb57tub
Should I use a little heat at the case halves to remove the cylinder hold down bolts? The case halves are not being reused. double nutting the bolts for removal. Removal all other studs will be done the same way. Thanks Jon
We use MAP gas. 2-3 minutes on the aluminum around the stud. Doesn’t hurt the case.
jb57tub
QUOTE(mepstein @ Sep 16 2019, 09:55 PM) *
Thank you for the reply. Won't be reusing the case , just wanted a good safe way to extract the studs. Case was ruined by the PO tightening the oil pick-up too tight and breaking the hold down inside the case. Was a good early 1.7 case. Picked up a good 1.8 case here from an earlier add. Jon
QUOTE(jb57tub @ Sep 17 2019, 12:54 PM) *
The heat will just make it easier no matter what. I've removed hundreds of studs on 911 engines and rarely break a stud and it's just less physical effort.
Superhawk996
The oil strainer pick up bolt is not part of the case itself.
