brcacti
Sep 18 2019, 01:21 PM
does this look like the correct 914 ignition switch? I noticed some are selling just the plug to fit into the metal???
brcacti
Sep 18 2019, 02:46 PM
forgot to add picture, here it is
theer
Sep 18 2019, 02:49 PM
Nope - not for a 914-4 anyway.. maybe for the -6??
It does look a lot like my '64 VW Karmann Ghia ignition switch, though.
jcd914
Sep 18 2019, 02:50 PM
That is not a 914 ignition switch.
You could probably make it power the ignition and start the car but it won't fit the steering column or unlock the steering.
Jim
Sprout
Sep 18 2019, 02:52 PM
Doesn't look right to me, but someone else might weigh in. My ignition key tumbler was just replaced with a 944-style one, and also replaced the ignition switch with a Porsche brand one, and they work beautifully. I will not buy the Meistersatz or any brand other than Porsche ignition switch again.
bretth
Sep 18 2019, 04:52 PM
That looks almost exactly like the one that went in my 66 Beetle. Nothing to do with a 914.
brcacti
Sep 18 2019, 05:56 PM
THANK YOU ALL VERY MUCH, got it from Sierra madre says on the paperwork and box porsche 914 70-76 but I called and they will take it back. So are you all saying I need to get a genuine porsche from the dealer ignition switch when I need one?
lierofox
Sep 18 2019, 06:06 PM
QUOTE(bretth @ Sep 18 2019, 03:52 PM)
Think you hit the nail on the head with that one.
https://www.jbugs.com/product/111905803D.html Looks like brcacti has one of these.
Can't find a single 914 ignition switch/lock cylinder that looks like that one at all.
The last ignition switch I bought was from Pelican for my 1975
https://www.pelicanparts.com/More_Info/1719...171-905-865-INTAre you needing to replace the switch, or is it the lock cylinder that's bad on yours, brcacti?
brcacti
Sep 18 2019, 06:08 PM
thank you
bandjoey
Sep 18 2019, 06:09 PM
If your metal body is there you can buy just the white electrical part. Thats all that quits on the switch.
http://www.autoatlanta.com/Porsche-914-Ign...witch-srch.html
porschetub
Sep 19 2019, 12:42 AM
QUOTE(brcacti @ Sep 19 2019, 11:56 AM)
SMC cock up heaps of orders,never dealing again,appears they don't really know what they are selling...don't be surprised.
Plastic piece that suits early Audi,VW and 944 Porsche also $8 on Pelican parts,mine still works after 3yrs,good luck.
Mark Henry
Sep 19 2019, 05:07 AM
I can say with 100% certainty it's a -67 beetle switch.
Also it's aftermarket as it's key is the shape of later VW keys, early factory keys had the VW bubble head.
IIRC they only cost around $10.
A 914 switch is just the switch, it doesn't include the lock tumbler and keys.
brcacti
Sep 19 2019, 05:09 AM
thanks for that
dr914@autoatlanta.com
Sep 19 2019, 07:59 AM
there are BASICALLY three different ignition lock and key tumbler combinations, 70-early 71 late 71 and 72-76
If you have a 72-76 you can use the 924 assembly, if you have the 70-early 71 you can use the 70-71 beetle assembly. Both original 914 assemblies have been discontinued. What we usually do however is restore the original to match the original key
brcacti
Sep 19 2019, 12:27 PM
Thanks to you all
