[quote name='bdstone914' date='Sep 21 2019, 07:27 AM' post='2748958']
@dangermoose @914sixer What brand of voltage regulator? DID you replace the alternator wiring harness when you replaced the alternator?
[/quote]
Thanks.....A good Elring one & have tried another unbranded one too!
What exactly is the alternator wiring harness? Haven't changed any wiring so far.
[/quote]
It is the harness that connects the alternator to the relay board.
Sounds like the new voltage regulator is bad. Inspect the harness for the wire condition. Remove the relay board cover, pull the three wire alternator connector and check the condition of the wires and connectors. Running high voltage could have damaged it.
Bruce
[/quote]
Thanks...
All the associated wiring looks good, but I could try replace it if I can find replacements. I will inspect it all again. Otherwise I will replace the board too.
