Full Version: Rear axle roll pins replaced with bolts?
90quattrocoupe
Is it possible to tap the holes for the roll pins and replace with bolts? Would this allow the use of 6 bolt cv joints? Possible to time sert the stub axle and sleeve the cv joint?
Greg W.
stownsen914
I modified some early 911 flanges to replace the roll pins with bolts to cure a persistent grease leakage issue between the CV and the flange. This is on a 300+ hp car. Apparently the flanges were flexing and allowing grease to seep through. With 6 bolts the leakage stopped. To do the mod, I had a machine shop tap the roll pin holes and install timeserts.
With that said, on my 914 racecar that has ~260 hp, I use stock 914 CVs with the roll pins, and haven't had a problem.
Scott
bdstone914
QUOTE(90quattrocoupe @ Sep 22 2019, 11:02 AM) *
Greg W.
What to you expect to gain?
The roll pin holes are 10 mm and the bolts are 8mm so you cant tap a larger hole to a smaller size. You can drill out two of the holes in the 6 bolt cv and use a roll pin.
