These are left over from the V8 conversion on my 1976 914. My hope is that they are priced low enough that you will select several (all?) so the shipping isn't more than the parts. I can't determine the shipping cost until you tell me which items you want, but I don't want to do a bunch of "what if" shipping scenarios. I will hopefully be shipping in medium (11" x 8 1/2" x 5 1/2" $14.35) or large (12" x 12" x 5 1/2" $19.95) USPS flat rate boxes. Pick up in Bellingham, WA is fine also.
Pictures of all items are here. . Reference number to the list below is in the lower left corner of the picture when you put your curser over the picture. The pictures are in the same sequence as the list.
Parts are $5 each.
Contact me by PM only. First come, first serve.
#1 Grundig radio. Doesn't work. Good dash hole filler.
#2 Brake pressure regulator. Not tested. Consider it a core.
#3 Voltage regulator. Not tested.
#4 Filter housing. I have no idea what this is.
#5 Fuel pump. #s on it are 0580463010 VW 043906091 Tested good.
#6 Fuel pump. No numbers. Tested good
#7 Rear trunk hinge
#8 License bracket (I don't know which one), bumper dogbone, and other misc stuff
#9 Ignition lock and related parts. Broken where shown in the picture. I don't know if any parts are missing. No key.
#10 Random wiring harness and boot
#11 75-76 rubber baby buggy bumpers
#12 Clutch rod boot at fire wall (new AA)
#13 Headlight switch (I must have replaced this for a reason)
#14 75-76 license lights (2)
#15 Heater/ventilation parts
#16 Defroster light
#17 Cover for heater/ventilation plenum
#18 Defroster knob
#19 Drain tubes, one funnel, 3 grommets. For rain tray or heater plenum?
#20 Front backing plate
