QUOTE(scottkrose @ Sep 28 2019, 11:07 AM)
This just started. I have found a green and black short to ground. It is the wire to the front right turn signal.
Where is this wire that is shorted to ground? How did you determine it was shorted? Did you remove the right side bulbs before testing? I buzzed it end to end and it was short to ground. Yes, I unplugged both ends, still short to ground.
I have bypassed by running a new wire around from right front housing to 4 way switch Now the emergency flashers all work.
So now all 4 corners turnsignals work? All four corners emergency lights work, yes. Right side blinkers and dash indicators are dead.
Running lights all work, but right side blinkers still do not work. I see no power on R of emergency switch with right blinkers on.
So you measure voltage with left side blinkers but not right side blinkers? Yes. On the emergency switch, L and R
Also now no lights for either side on tach.
You should see something if the left side turnsignals are working. Check the bulbs just to make sure they work. You can also check them by removing the common wire between the 2 bulbs and connect either one to ground and try the 4-way flasher.
I do not know how to get at the turn signal switch.. this is a 1970..
I believe you start with removing the steering wheel, then continue to dig into the other components there until you reach the turnsignal stalk. It could be that the shorted wire affected the turnsignal contacts or wires.
