ClayPerrine
Sep 27 2019, 06:38 AM
WTB - Shifter assembly for tail shifter transmission
Clay
Rusty
Sep 27 2019, 06:39 AM
Do you want that Rennshifter back?
ClayPerrine
Sep 27 2019, 06:41 AM
QUOTE(Rusty @ Sep 27 2019, 07:39 AM)
Nope. Going to return him to dead stock.
Rusty
Sep 27 2019, 06:44 AM
QUOTE(ClayPerrine @ Sep 27 2019, 06:41 AM)
Sorry, don't have a stock early shifter in my stash for you.
RohJay
Sep 27 2019, 07:06 AM
No doubt you will find one easy enough.
BUT just in case you don't, I have a complete shifter and linkage that you can have for free.
The catch is shipping : i'm located in Sri Lanka.
Been lying here since I converted to Side Shift.
I just hate seeing it go to waste.
Drop me a PM if you need it
Sep 27 2019, 07:53 AM
I'm sure I have one if you don't find one local.
jesse7flying
Sep 27 2019, 10:57 AM
Clay, I probably have what you need, you just need to come over and pick through it.
Jesse
ClayPerrine
Sep 27 2019, 12:20 PM
QUOTE(jesse7flying @ Sep 27 2019, 11:57 AM)
Jesse
Jessie,
I will give you a call tomorrow.
Thanks,
Clay
theer
Sep 27 2019, 02:01 PM
I converted to side shift recently & still have the original tail shifter bits. Same deal as others: free for cost of shipping.
bdstone914
Sep 27 2019, 11:17 PM
@ClayPerrine Clay,
Are you aware of the common wear in the pivot pin for the ball? Have to take apart to see the wear. Half that I took apart had half worn thru pins. Round pin was D shaped from wear. Same prob lm em for a 911 shifter for the 901 trans. Easy to replace with a hard 6mm dowel pin welded into the small bracket on the side of the shifter base.
Can get pics of the worn parts if needed.
Bruce
IronHillRestorations
Sep 28 2019, 06:50 AM
6 or 4? I have a 6 rear shift bar
ClayPerrine
Sep 28 2019, 07:13 PM
Thanks to everyone that replied. I found one in my parts stash.
