For me, I've decided I'd rather use a Type 4 pump.
The proper solution is to pin the shaft to the pump housing which involves very basic machine work.
So it sort of depends on the definition of what is an easy fix. Can it be done basic hand tools and a drill easily (<1hr) - no.
Can it be pinned easily on a vertical mill or by a machine shop in an hour or so. Yes.
In my case, the problem has been finding a single good pump. I've accumulated 5 to make two good ones and maybe a 3rd by doing some basic machine work that some would call blueprinting but I won't call it that since I don't have a print that is known that I'm working to.
I also intend to make a basic test fixture so that I can test & verify pump performance before it goes back into an engine.
I saw someone on classifieds looking for lots of cores to rebuild. I assume someone is looking to get in the business or rebuilding these. Not me, but, I say Hooray.
Would be nice to have a viable option to find rebuilt pumps with a properly pinned shaft at a reasonable price below the insane cost of new parts and even then, the housing which is a key piece is NLA.
Photo in the top left corner looks like one I received, shaft way too deep. In my case, it turned out to be what I believe was a type 1 gear set in a Type 4 housing. Factory error or previous owner just making do? I don't know but it clearly didn't match any of my other pump shaft lengths.
